Battery light
    Battery light
    I need some help. for the last few days my battery light keeps coming on so I took it and got a new battery thinking that would help but it didnt. When I am stopped at a light it comes on and when i gas it it goes off. Any ideas on what could be wrong with it? Please help If yall have any ideas. thanks
    Formerly: sheisanonymous
    Alternator is also a possibility
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      So when I had the guys at Auto zone check the Battery They should have done that too?
        According to my experience , you should tell them to check the alternator
          Most likely your alternator isnt charging. Or that ouput plug the one that plugs in not the one thats bolted is not pushed in all the way. Mine used to pop out then i zip tied it. But if you go to autozone should take out the alternator and let them test it. Usually if they just test the battery they just load test it and doesnt tell you the condition of the alternator.
            Cool thanks.
              I know when I was having problems the guy at autozone said the cable running to the alternator would go out on ours cars after a period of time but sound like the alternator is gone to heaven I did have another one sitting around but I think I sold it!
              99 GS300 (Aristo) 2JZ Power
              Bought from:gdout, bb6-sh
                I took it in and had them test it again and he said that everything was good on it. Alternator was real good. So im stumped. Ill check the cables or wires that go to it.
                  Sometimes it's as simple as adjusting the belt tension.
                  Black Housing DIY 1991 Wagon Morimoto Retrofit
                  JDM One-Piece Headlight Lens Repair
                    Test the charging system with the alt and battery still in your car and the car running with nothing on, then retest the system under load.
                      Does the counter shaft have anything to do with it? The guy at Auto Zone said that was real loose. and it was.
                        Ehh countershaft? The only countershaft deal I know is in the trans for the vss. He talkin bout the shaft inside the alternator? How loose are we talkin bout? So umm how did he test that? Unless you have maybe a bad bearing in the pulley? But that would make excessive noise eventually it would sieze up. Hmm pictures of what the guy was talkin bout?
                          Its the small belt by the timing belt but my dad said that had nothing to do with it.Todd is about to tear down the engine to do the head gasket again so maybe well figure it out then. He doesnt know why it is on either though.
                            Well worst case scenario the lil chip (forgot the name at this moment) inside the alternator is sending a bad signal. Does Todd have a volt meter? He can test if the alternator is charging the battery. Just hook the leads to the battery with the car on and it should read 13.5 or so. Another thing you can check are the grounds that can sometimes throw it off.
                              i once had this issue, and autozone tested my alt, which was fine. One possiablity is to check the harmonic balancer (crankpulley). The outer ring on mine was loose/slipping...nearly falling off. Check that if everything else is fine and you still have the problem.
                              Seattle Silver crew #5
                              Member of the Midwest Car Club.
                              ..........2004 accord ex v6 - J30A4.......................... 91 accord ex - JDM H22A -- Long gone...
