Cold Idle problem
    Cold Idle problem
    Is there a way to adjust the cold idle, because when it's really cold in the morning, my car idles at about 2500 - 3000 rpms for about 1 1/2 minute.
    thanks.
    Big 16g Turbo/H23 Head Swap/TSX Projectors
    Test your fast idle valve....it doesn't sound like its working.
      Yeah, that's way too high. it should be about 1,000 RPM lower.
      First response would be a vacuum leak, but it should start surging because the ECU should cut fuel at that point (above ~2000 RPM and closed throttle).
      What's the hot idle?
      I wonder if the throttle is open a bit for some reason, which would stop the ECU from cutting fuel. Then on top of that a vacuum leak, or a malfunctioning FITV as arctichonda suggested.
      Not an expert, its just what my thought process lead me to.
      Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
        close the FITV all together. Yes, turn it all the way closed. Should fix it. If it doesn't then u'll need to cap of the vac line running on the back of the intake mani to the air starter valve.
