I dont know if this is the right forum or not but it's technical. today i was driving along and i had to get on brakes. when i did i had to get all the way down on the brakes, it has more than enough brake fluid and i dont think it was leaking anywhere. so what do you guys think it is???????? please help
brakes
Could be your master cylinder if you have pressure but the brake fades away. If you brake hard then you should feel the pressure but the brake will fade to the floor. I had to get mine replaced - $250 with new fluid flush, new fluid and back brake cleaning/adjusting cables, new master cylinder and labor.
Tim
