wierd electrical problem...
    so i start the car up in the morning and let it wram up for 10 munites.get in drive down the road i notice lights are dim.then tach and speedo go dead.soon my radio shuts off and wipers are barely moving.i shut the car off and try to start it back up no crank what so ever.give it 15 seconds cranks right up.barely make it to school all of the electricals barely gettin enough juice to function.park it get off school thinking i'm gonna need a jump (thought it was an altenator at this point.)starts right up everything works till i get home.i couldnt take it to work so i can test the alty on the vat40 so i hook up the dmm and see its only pushin out 8 volts when all the electricals are powered up.at this point i'm like alrite i just need the car tonite and this altenator has 10k on it and its a reman so i thought it shit the bed.replaced the altenator pushing 11.2 volts min.
    go to a meeting same shit happens.if i turn the car off it will not start unless after a while.the car also feels weak.
    i'm thinking main relay but none of the symptoms i read in the archives match up.it sucks its my daily and i get no time to work on it.i think now its completely dead it barely got me home it starting bucking real bad as soon as i pulled in my street.
    ILBB
    People I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
    Mk3 Supra Member #2
    Originally posted by DarkShadow707
    The world needs to be reset.
    bump
    Mk3 Supra Member #2
      I'd be also looking at a Dead Battery. Possible one of the Cells has sulphated and died. The Alternator is trying to charge the battery but it is not accepting or holding the charge.
      A Flat Battery will give you false Charge Rate Readings.
      Also check all your main Battery Wiring & Grounds for Security and cleanliness.
      Cheers
      Geoff
        Take a look at the battery cables also.
          i think autozone give free battery and alternator testing if you can make it over there.
            Cheers
            Geoff
            Yes. And lower voltage could be causing weak spark and lazy injectors, as far as my knowlege tells me.
              thanks for teh input guys.even though teh battery is a year old.
              ILBB
              Mk3 Supra Member #2
                do this .Start your car and let it idle. Take a multimeter, turn it to direct current volts.Stick the red on the pos and the black on the neg battery terminals. Its should read 12-14volts. Any less and your alt is not charging properly. any more you are overcharing.If you get a low reading Start with your battery, then your battery connections.Fuses. If that checks out, move on to your alternator connections. should be tight and clean. After that, check your alternator/ac drive belt tension. At the most it should only be a 1/2 of play up and down. if all that checks out,then it is more than likely that you are drawing power somewhere or you have a short in your alt wiring. If you have an aftermarket stereo, take the face off and retest your charging system.Let us know.
                  i think its teh altenator belt.about a 4" of the ribs section has fallen of, i'm surprised it aint broken yet.
                  I'm heating up the garage so i can change it.
                  ILBB
                  Mk3 Supra Member #2
                    sooo???....how'd it go?
                      I went through the same thing when it first got cold it was the alt. I changed the battery 1st. because autozone said the alt. was ok but I changed the alt. next and no problems other than a loud high pitched noise when I 1st start then it goes away.
                        ILBB
                        lol!!! damn that sucks. Let us know how it is after you finish changin it out.
                          yeah guys it was teh altenator belt.alot of it was broken/cracked.its because i left it loos for so long i didnt feel like tightening it.anyways problem solved and for $12 fix i aint mad
                          ILBB
                          Mk3 Supra Member #2
                            Pimp!!! glad to hear you fixed it.
