speed change tire rates
    This is a fun little tool i found while surfing around TAC (TorontoAccords.com)
    you input your current tire size and then put what your new tire size is and then it will tell you how much your speedo will be off by. Either under or over hahah.
    http://www.miata.net/garage/tirecalcold.html
    1990 Accord EX -Stock to no beyond
    Originally posted by yeamans17
    you'd better soak the nuts in pb blaster, otherwise you'll snap them off
    "Be who you are and say what you feel, because those who matter don't mind, and those that mind, don't matter" - Dr.Susses
    Vouch - | gloryaccordy | aznkid.com |
    good job, but its in the wheels and tires sticky.
