Help No Power Steering!
    I wake up this morning and I find a big pile of power steering fluid all on the ground and my steering wheel was hard.I put more fluid in and it squirted all over the place.I'm trying to figure out the problem.any suggestions would be appreciated.
    Project EP hatch on the way
    Could be the pump. Is it spraying onto the hood when it is closed?
    FSAE(F Series Accord Enthusiasts) "A dying breed..." #15
    Need parts? Check out my 1990 EX part out!
    http://www.cb7tuner.com/vbb/showthread.php?t=60011
    www.clemsonscc.com
      Yea it is
        Bump
          Well first thing clean the area with brake clean or something. See if a hose is ruptured or something. maybe the pump took a shit too. But cleaning it will help you find the leak a lot quicker.
            The thing is that I have an h23 swap and I used the accord power steering line and the power steering line that connects to the pump does not stay in place.anybody have any suggestions they will b greatly appreciated.or pics of how they hooked up the power steering.
              sounds like your pulling air into the system
                ^what do u mean?.the thing is that u could see the power steering fluid squirt out of the hose that is on top of the pump.
                  if the reservoir is foaming your pulling air into the system...if its squirting out of the pipe, replace the pipe.
                      Its actually doin both.any way I can solve this problem?
                        OMG replace the piece that is leaking!
                          Thanks I really appreciate it starchland
                            some pics maybe?
                              ever try removing power steering? it handles alot better.
