I've Searched and only found similar cases of this.... I have 91 ex auto, starts in 2nd and goes right to 4th. No 1st, no 3rd, no overdrive. i know my fluid is just a hair over full and I recently changed it (within 6 months of this). My car just started doing this yesterday after I removed my sport switch and wiring to the harness on the shifter and swapped my gauges for a cluster that doesnt have sport mode Since neither the lights nor the gas gauge worked, temp was picky too because of a bowing gauge face (white face gauges. Cluster came from a 91 according to info written on it.
What the hell is causing this. it was fine b4 i did either of those 2 and i have since hooked the sport switch and wiring back up. Could the gauges have anything to do with it? Also, the d4 light is on when in any other gear but d4 and goes out when I put it into d4. Car does not downshift to 3rd from 4th even manually. I only have 2 and 4.
PLEASE HELP?!?!?
PLEASE HELP?!?!?
