hesitation/slight bogging
    First off i have a jdm h22 5 spd with a p28 ecu. When i drive at normal speed 50-55 i feel the car hesitate and slight bogging. And when i come to a stop my rpms drop around 650-700 and it sounds like it's about to shut off. But when i tap the gas it goes up for a few seconds in then comes back down. I thought it was the egr but i was informed that i should have that problem with the p28 ecu so im stuck...
    "Know Your Rank"
    Check idle adjustment.
    1992 Accord LX CB9 149K Stock
    2014 F350 Platinum CCSB SRW
      i do need to adjusted it but that will cause the hesitation and slight bogging
      "Know Your Rank"
        is this p28 tuned? and where did you get it from>?
          i don't think it's tuned but i know it has a h22 base map.
          "Know Your Rank"
            "Know Your Rank"
              might be a vacum line, then can cause alot of idle problems and bog you car down. Could also be a stuck pcv.
              "Up Down, Slide To Slide"
              Members ride thread- ]http://www.cb7tuner.com/vbb/showthread.php?t=63019]
                check all the vacuum lines by squeezing them off one by one with needle nose plyers. see if the idle changes on any of them. next check the pcv by pulling it off the valve cover and feel for vacuum, if there isnt any, you could have a clogged passage and youll have to clean it. also when you pull the pcv see if the rpm changes, if it doesnt and there is vacuum at the pcv, get a new pcv valve, there super cheap. hope this helps
                new ride
                07 cobalt ss/sc
                  Yea P28 doesnt check for EGR thats why it doesnt matter. YOu gettin any CEL or anything?
                    i'm check those lines tomorrow. NA i don't have any cel's
                    "Know Your Rank"
                      oh i forgot to add:: i have notice when i put my windows up or down my rpms drop until i'm done.
                      "Know Your Rank"
                        "Know Your Rank"
