small suds/bubbles in oil...also oil with spark plugs?
    why would excessive oil be present in the holes where the spark plugs go?
    also, are bubbles/suds in ur oil a sign of the head gasket going bad, even if the coolant level remains full?
    thanks
    dont kno about the bubble but its either ur spark plug tube gaskets or the gaskets that ususal come in the pack when u peplace ur valve cover i guess their called vauvle cover plug gaskets
      Hmmmm... About the oil. Check it one morning before you crank it up and see if there are still bubbles.
      1992 Accord LX CB9 149K Stock
      2014 F350 Platinum CCSB SRW
        tube seals need to be replaced
        http://www.cb7tuner.com/vbb/showthre...highlight=tube
        My Members Ride Thread
