Vtec
    Vtec
    well my VTEC pressure sensor wasnt wired up because the wire broke at the pin in the connector so i just re-wired it to get rid of my CEL. well obviously VTEC wasnt engaging with the CEL, but even after i cleared it, it still doesnt engage. i dont have a CEL and i have oil in the car, any ideas?
    new ride
    07 cobalt ss/sc
    anyone have an idea??
    new ride
    07 cobalt ss/sc
      Is your car up to operating temp. You sure you plugged it in the right opening?
        yes everything is wired up correctly, maybe i should let my car warm up and then try
        new ride
        07 cobalt ss/sc
          yea you gotta be at operating temp b4 it will engauge
          PSN ID's:Tidashoni
          1992 Accord EX Coupe
          My FS Thread
          Not so DD 2013 Subaru Impreza WRX STI
          Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
            ur temp must be up 4 the vtec to engage. i had the same prob with my ls/vtec
            if you got something smart to say, guess what, i dont care.
              well even with the car at operating temp it doesnt engage, my rev limit is at 6500 instead of 7200. any ideas?
              new ride
              07 cobalt ss/sc
                What type of ECU are you using?
                  P13
                  new ride
                  07 cobalt ss/sc
                    bad idea to rev your car like that when it's cold. and is the solenoid itself bad?
                      i havent checked the solenoid yet, i dont drive it hard when its cold. i let it warm up before i do anything hard on it.
                      new ride
                      07 cobalt ss/sc
                        Are you driving the car or revving it in neutral??? If your revving it in neutral bad for the motor and vtec wont engage.
                          you sure you cleared the CEL? 6500 limit sounds like its cold... disconnect the battery for a while and try again.
                          btw, if you tie the d6 pressure sensor wire to the a4 solenoid wire, it wont check for the pressure sensor.
                            no im not revving in neutral this is when im driving, and mike what do you mean "tie" the wires, do you mean getting them mixed up?
                            new ride
                            07 cobalt ss/sc
                              tie [tahy] -verb (tied, ty·ing)
                              14. to make a tie, bond, or connection.
