foglights
    foglights
    putting my foglights on my 92 everything would be the same as the 90 right?
    meaning the plug under the fuse panel. its just pulling that off hooking it up and running wires
    Yes, it would be the same. I think I know what you mean, but if it's an OEM harness, the 90/91 is diff. from the 92/93. The 92/93 has 1 extra wire and I think 1 connector is diff. And I'm not sure if that even makes a diff But as far as both fuse box connections, they are the same.
      thanks ill find out tomarrow ill let everyone know
        lights are done everything was the same pluged right in, so now its time to get my hid's or should i say time to save $
          Nice, so what is your exact setup? So, USDM or JDM 92/93 fogs?, what harness are you using? Good work!
            jdm, the wrong harness from 90/91 there for sale now
