broke bleeder vavle on rear drums.
    well i blead my brakes today and i broke my rear passenger side bleeder valve.it was a bitch but the other side was fine.for some reason theres no fluid leaking out at all.but should i get this fixed soon?what parts are needed,just the backing plate?again i broke the bleader vavle it was so corroded and rusty it snapped.my brakes are working though but i want to fix this soon.what parts do i need i am going to the junkyard tomorrow.thanks.
    you may need the whole rear caliper if the broken bleeder valve is stuck and/or does not completely twist loose to be replaced by a new valve screw.
    Once upon a time I took a joyride in a Huayra...
      You COULD try to get the broken portion out of the caliper and get another fitting at ACE...but it would be to your best interest to replace the caliper.
        its drum brakes.and half of the bleed screw is still broekn off inside there,its not leaking though.i am gonna go to the junkayrd later today.should i get the entire brake assembly???what do you mean get the caliper.dont i just need the backing plate?thanks,
          can i just get a new wheel cylinder?isnt that what the bleeder screw goes into?cant i just replace that?thanks.damn the one i broke was so rusty it sucked ass.i think i can just replace the wheel cylinder?let me know.if i replace the wheel cylinder it says to use sealent behine it???wyf.what kinda sealent and why?i hope its just the cylinder.
            bump.i dont understand why its not leaking.i mean i broke the fucker off.lol whi isnt it leaking.maybe it broke after it was closed?i dont know but i just need to know what part it is ineed so i can get it later on or tommorrow?is it the wheel cylinder?is that it or that entire dust cover?
              bump^ once again. sorry just trying to see what part it is that i need....stupid fucking bleeder valve just had ta break.
                ok cool,tommorrow i am going to get wheel cylinder.so thats it huh.aswsome.next time i'll be careful not to be so rough.but it was rusted bad.the online manual says to put sealent on the back of the new cylinder?????is this true?and if so why?what kind?oh ya will i have to adjust the parking brake?and also can i get away with just bleeding the rear brakes again or all 4?thanks.
                  thanks man,always helps to know as much as i can.i appreciate your quick responses too.
