Head Swap
    Head Swap
    Yes i was wanting to know if a head from a f22b1 will work on a f22a4 block and what head gasket set would i need to do this swap and will everything bolt up to the a4 intake and exhaust. Any help would be appriciated
    ok i ment to say this is a f22b2 non vtec head
      what's the point of it ? they look like they are the same to me
        he may have a warped head or bent some valves..
        they are the same head.. replacement parts should be the same
        Praise The Lowered...
          Um... no. The intake and exhaust manifolds are different, and would require a bunch of work, including those new manifolds, to work. But the head GASKET is the same, and the head would bolt down on to the block just fine.
          Visit us at http://www.valleyspecialists.com for all of your Honda and Acura service needs!
            So the intake and the exhaust are different? And also i am doing this because my friend had a f22b2 with a good head and my a4 threw a timing belt and i had this head given to me
