massive leak!
    massive leak!
    okay guys something is not right, i got my clutch installed about 3 days ago, everything was running just fine and smooth. all of sudden today i get this hardcore oil leak. i noticed it because the oil light came on, so i check the oil on the stick.. nothing. so i put a quart in, start it, all comes out in a matter of seconds. here are some pics, maybe you guys know?
    i'm fucked if i cant figure out what it is. it cant be the oil pan gasket, drain plug, or the oil filter. i just dont know.
    Oiii that does not look good at all. Is it dripping visible? Get some brake clean and clean that area up start it up for a few sec and see if you can see where its comin from.
      oil pump or front main for sure, have fun pulling the motor
      fuck the bitches that stole my car jan/1/2006@7am from montesano wa updated: The Warrens from Malone Wa were found guilty for possesion of stolen property in the 1st*and were ordered to pay $2489.69 in restitution, only cause the shell was not found
      R.I.P.
      Vouches from: Snailin91, Caution, 2G6, Jdmf23accord, Boosted_StinkyNuts
        Looks like your seals maybe leaking from the inside of that timing belt cover.
        Engine block seals like crank pully seal, front balance shaft seal as well as that rear balance shaft gear O ring seal.
        Also check above that same side on the cylinder head (need to remove)
        timing belt cover for a nasty cam seal as well.
        If I was you I would get this fixed before your timing belt starts slipping from these oil leaks off all the gears and this also causes premature wear of the timing and balance belts!
        -Mike from P-town!
          -Mike from P-town!
          well what kind of work is this consisted of?
            -Mike from P-town!
            umm dude there is only one balance shaft in his motor and if there is any oil on the belt anywere they need to be replaced the oil will destroy the belts and im sure there is, and dont give helpinfo to people in need when you cant even name the parts correctly ......and it might be in your best interest to drop a new motor in it
            R.I.P.
              okay well i was just out there examining the visible belts, and surprisingly i didnt see or feel any oil on them. if that helps.
                belt that are on the inside of the timing covers ther are more then just two actually there are four alt belt, p/s belt, b/s belt, and timing belt
                R.I.P.
                  i'm just fucked, with the lack of experience and tools that i have, i dont know what to do.
                    Have you installed the bracket to hold the oil seal? Its the front balance shaft seal I think, can't remember now :P Supposedly a common thing on these engines, hence Honda created a bracket to hold the seal in place :P
                    I didn't know about it and the seal popped out, had it replaced (along with the timing and balance shaft belts) for $240 at the junkyard, which was where I noticed the leak.
                    Later found out about the seal retainer and had it installed.
                    Maybe that's it.
                      well it comes out in a stream in two locations
                        may just have start dissasembling and find out
                          man its like know one can read he said he dosnt have the tool to do it be sides im going to kansas to do it for him for free just because i can, motor swap people another one is joining the the darkside
                          R.I.P.
                            you serious?
                              you serious?
                              yes
                              find out how much a gray hound ticket is from seattle to you and back and i will do it for nothing you just need to feed me and let me crash on your floor... i will help you locate a motor and the stuff you need and i will teach you everything you will need to know on swaps
                              R.I.P.
