I'm having a weird problem with the power windows in my 4 dr. EX. The problem existed before I got the car, so I have no idea where to look, or what happened when they went out, but only the back ones don't work. (which really sucks cause the back right window is halfway down, and won't move either way).
I heard that the master switch can make all of the windows not work (even if you try rolling down the right rear window FROM the switch on the right rear window). Is this true?
Is there a way to test the motor? I tried putting a power and ground to the plugin from the switch, but all i got was sparks. Definitely a weird problem to diagnose, so any help would be much appreciated.
