My room mate's accord started puking oil from the between the block and where the filter mounts onto. I checked and it's not the filter. I was wondering if anyone here has changed this part, and if so how hard was it?
oil leak from filter adapter?
Very common to have the oil cooler oring leak. It gets hard and cracks. You will need to remove the oil filter and then use a wrench and remove the oil filter threaded stud and the cooler comes loose from the block. Also make sure that the oil pressure switch which is directly above the oil cooler isn't leaking. Also a very common problem and less than $10 at the dealership.1993 Honda Accord LX-auto--bone stock for now.--248K
1997 Honda CRV--auto--bone stock--wife won't let me touch the CRV. 150K
Need any performance parts? Check out my website or email me for prices.
www.CARMandP.com
Working on my H23 sway for free
