idle and signal problem..
    My idle is playing a game on me..when i step on the brake it gives me this idle problem..and for the signal..whenever i signal left or right it gives me a hazard signal..anyone know whats wrong?
    the idle problem
    EDIT: i'll post the vid of the signal problem when the car is cold..
    What is your car idling at? Check your idle screw to make sure its inl, if not that, disconnect your TPS and see if it stops, it could be that or an IAC valve.
      Adjust your FITV. Just screw it down.
        My car if i dont step on the break, it idles at 7-800 rpm..Whats the tps?? this only happens when the break is step on..
        I did that already, And couldnt solve the problem..
          TPS = Throttle Position Sensor. Hows your coolant level? That can cause a fluctuating idle in some hondas and if it has air in the system. SO if you dont touch the brake at all it doesnt fluctuate at all?
            If i step on the brake it gives me that idle, if i dont then it stays at 7-800 rpm..Coolant and everything is fine..the car did this even before i got it..
              Check for vaccum leaks.
              1992 Accord LX CB9 149K Stock
              2014 F350 Platinum CCSB SRW
