Originally posted by SilverShadow
from the manual that i downloaded in here from the sticky on top it says.
"#14 tcm. short or open FAS wire. trouble in the PGM-FI unit.
the symtom is-> trasmision jerks hard when shifting."
now i don't know what the FAS wire is or where is located.
if your shifter is stuck on park then it might be a few different problmes.
first try to hear a clicking sound near the shifter when you press the brake.
second check the shifter cable. sometimes they go bad. i had a similar problem but i was able to take it out of Park. all i did was that i went to the tranny, where the shifter cable goes in and i tryed to adjust it. then clean the shifter console and made sure that the shifter hole in the shifter console lined up.
but make sure you download the online manual it's a great help. it has helped me a lot during the 6 months that i had auto tranny problem.
