Transmission problem or not? Please Read
    when i start up my car the RPMs keep going from 1 grand to 2 grand repeatdly! then when im driving it it seems not to drive right anymore after 1st gear when it gets to 2nd it when u say u would go to smash it the RPMs dont even go up quick anymore and its been Riding Weird!
    Bump!
    dude!.. your cars gettin ready to blow up!.. get rid of it as soon as possible!!!..
      sounds like torque converter slipping maybe.
      check the fluid, possibly change it but if its the torque converter your in for a alot of work.
      Retro!
      Hater
        Have you pulled the codes yet? Found this link that Bustedlx posted (thank you BTW) it has both the ECU and TCM codes in a pdf file at the bottom of the page.
        Accord, the next best thing to WoW!
        Got Goat?
        Dear maximonline.com,
        found porn:
        Wikkedv16
        "my sister has one of their mufflers.. pretty nice quality muff..
        hasnt dulled down.. no rust.."
        Screw Toby! http://www.savetoby.com
          ok dude let me ask u something. is it automatic tranny or manual tranny.
          after the the 1st gear is changed what happens.
          does the tranny goes directly to the forth gear?
          if yes it might be the shift control selenoids? but first u got to check the TCU codes.
          that is how mine started then the tranny went out. i had to get a used one from a junk jard.
