F20A SOHC with dual runners?
    When I got my F20A SOHC, I had to use the intake setup from the F22A6. The F20A SOHC used the single runner and was rated at 130 HP. Using this engine with all the F22A6 goodies, do you guys think the HP numbers are close to to the F22A6? The main reason I'm asking is because I've literally blown away 4 different 92-93 EX's.
    If you "blew them away" chances are it wasn't simply because of an intake.
      was it cuz yours is manual and theirs were automatic?
        it can be, in the f20a motor do u have to use a differnt ecu? what the the f20a motor use....?
        Retro!
        Hater
          Does "goodies" include the cam, perhaps?
            I'm using the 92 EX ECU. By goodies I meant the intake setup and everything attatched to it (vaccum lines etc). Nothing pertaining to the engine. I'm running with the JDM F20A A/T BTW, which leads me to another question to. My tranny shifts at ultra high RPMs, like 6100. It's only a couple hundred below redline. It does this in first and second. Is this just a trait of the JDM trannies or do all 4th gen A/T shift like this?
              i notice with the 92ex ecu swap that i shifted higher as well...just barley under redline..alot further than my 91 ex ecu, the pt3.
              Retro!
              Hater
                i have a 93 se and mine shifts below the redline
                I don't lie, I bullshit
                  Well at least I know that it's shifting right. I guess I need to hit the dyno if I want to know what HP(WHP) I'm running. Thanks!
                    Hey I have the same set-up, but my iab isn't working so my butterflies are always open..
                    My Ride
                      Cool to know someone else has the same setup! Would the butterflys being open all the time hinder your acceleration on takeoff?
                        on the low end, yes
                          Originally posted by HondaFan81
                          on the low end, yes
                          That's what I thought. Thanks.
