How does everyone get their cb in the air?
    So I was wondering how everyone gets the car off the ground to do oil changes, brakes, etc. Ramps, jack stands, lifts? I ask because I'm looking into getting a set of ramps and/or jack stands, and was wondering if anyone had any recommendations.
    any car with a stock suspension can be put on ramps, or be lifted with any regular floor jack and held stationary with jackstands.
    ramps wont work with a lowered car, and depending on how low, many jacks wont fit under either, you have to fork out the cash for a low-profile racing jack. but until that point, youd probably be fine with one of those combo kits that you can get cheap at walmart. it includes a jack, jackstands, and wheel chocks. thats the kit i used for the longest time, and it serves most purposes well.
      jack and jack stands
      if ur car is too low, just drive onto some 1" 2x4s to get the jack to clear under the car
      Formerly 91AccordExR33
      11.68 @ 127mph
      417whp/375wtq
      Sold: 8/2016
        I can still use a regular floor jack, my drop isn't too low.
        If I really want to get up on ramps, I learned a trick.
        I took a plank of PT 2x8, cut it in half lengthwise, and put it on the ramps to make the climb less steep. It works but it takes some work to get it right.
          Jack and jack stands.
          My car is too low for most jacks. I need one of the racing jacks. I usually lift it up with the scissor jack and put a large cinder block under one wheel then lift it with the regular jack...
            not even a low profile floor jack can clear my car by itself . 2x4 ramps work to get a normal jack under there. with a car very low what i also found to do is to take the scissor jack in the trunk and lift the car from the towhook up front until i can get my normal floor jack to clear. it's a pain to do.
            i'd take mike's advice on this one.
            1cor10:31
            - 92 LX coupe
            - 96 EX wagon (sold)
              I just hit a switch!
              lol, but I used to drive onto a board, then use a jack and stands. Now i just use a jack and stands, no more boards.
                1" 2x4
                My jack doesnt fit under by like 1/8" of an inch, but i can pick up the front of the car with one hand and slid the jack under with the other hand. works pretty well.
                    Originally posted by accordaffair
                    llmao
                    just curious...i know our car have the 4 spots where you can put jack / jack stands.....but if your gonna put a jack stand lets say on the driver side...where do you jack it....i put the jack where the sway bar bolts up ...u think thats safe?
                    My Members Ride Thread
                      my cars too low for a regular jack, so as said i just drive up onto some 2x4's and then fit the jack under there
                        1) put a piece of wood in front of your two frount wheels (typical 2X4)
                        2) run over it, this picks up the car
                        3) then put the ramps in front of the tires
                        as you can see it picks it up enough to clear the stock lip on a car with coilovers.
                        4) then drive on to the ramps. done.
                        for cars with lips use additional pieces of wood, usualy thinner plywood does the trick. later.
                        Avoiding dirt at all costs
                          Great DIY TypeG
                            lol. this guy has a DIY for everything.
                            you should post a DIY DIY
                              i used to use wood and i also had a scissor jack with a 19mm nut on it that could crank it up pritty fast... but now i air it up
