ok so my dizzy went so i gota new 1 (usdm external) so i took apart my old dizy took the coil out & the doubel wire, put it in the new 1, hooked up the wires, spliced the black & yellow togather on the inside wrapped it in elec tape and she started right up, drove her to work ran beautifly.....today i soldered that wire because it was really short and i didnt want it to come loose while driving.... i put the cap & rotor back on (yes correctly) and now no start, just cranks took it backa part inspeceted it and i cant get it to start can someone pLeaAAaSSe help me
converted external dizzy to internal ran fine now no spark..
Problem Solved
okk so my eng came with a spare coil when i got it and that was the only thing i could think of that could be causing it to not start, so i swaped them and she started right up
--my advice is if you solder in the distributor, disconnect the 2 wires going to the coil
who needs a manual anyway
JDM is the way to play, all day every day
