power steering removal?
    I think I'm having a few problems with my power steering, it whines when i turn, and it feels like the P/S comes in and out every once and a while. So I've decided to just get rid of it, Iv'e driven a civic without power steering, and it's not too bad.
    So, I was wondering if there was a DIY on PS removal (I searched). And if anyone's got some tips on driving/removing....anything on Power Steering, talk to me. thanks.
    -Cole
    Well easiest way would just be take the belt off the pump itself.
      Are you trying to remove the whole system cause you will have to loop the lines!
      99 GS300 (Aristo) 2JZ Power
      Bought from:gdout, bb6-sh
        well, it seems I'm having some problems with my power steering now, and Iv'e always wondered how hard it would be to remove it,........and another question for those who don't have PS, do you wish you had it???
          Bleh its the same. Getting out of tight parking spots is a bitch but you get used to it.
            NaiL, you mentioned taking the belt off the pump and I wouldn't have PS anymore? Could it be that easy?, if so, do you have a picture of where it's located?
              Your power steering pump is the top one just loosen the tension pull off the belt and no power steering. If you like that then you can take out the whole system but thats the easiest way to take off power steering and keep all your stuff looped.
                sweet, i'll try it
                  Oh shit.
                  Why do you have to loop it?
                    SO the rack dont dry up and it lasts longer.
                      Originally posted by Maple50175
                      Oh shit.
                      lol i take it you didnt loop yours
                      R.I.P. 6-10-07
                      (\__/)
                      (O.o )
                      My Rotor DIY
                      I'm not perfect i will make mistakes if i do just point it out to me
                        LOL Taking that cooler off in the front is a bitch I warn you it's a trick you got to do!
                          you left us hanging. whats the trick. i am considering going ahead and remove the whole thing. i have had the belt off since 04 and it ain't bad. but i might as well remove the whole system.
                          91 Ex CB9
                          JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
                          W.I.P.
                          p72 ecu on Hondata
                          To Come
                          Weight Reductions
                          R33 or R34 front end
                            Well you know there is a 10mm bolt holding the cooler to the front of the car. Well once you take it off it just hangs loose and some may have cut it off, well what I did was just push down on the cooler and it popped on the outside so I could get the hoses loose and loop them!
                              pull all the lines out of the res..then under the car there are too lines behind a splash sheild,one goes straight to the pump the other is a return, take those out and cut the lines so that you just have the open bolts,then just weld the open end, smooth them down, throw em back in the hole and your done with the under neath, then just remove everything up top, pump res, cooler, lines res, pump bracket, then just get a belt, i got an 86 accord belt, they had 2 sizes and i got the biggest one and it fits nicely.....there are days i wish i had it to be honest...if you like turning the wheel easy and not really
                              having to put alot of muscle into turning. keep it in, replace your pump since thats what it needs and stay away from removal........
                              93 Accord- SOLD
                              94 Civic- F22a1 Swap, current DD
