ok so im finally pissed off and quit close to blowing my car up like sky high
so base line here i have a f22/h23 motor t25 turbo setup all brand new internals and such 450 injectors
so im notgetting fuel or spark my fuel pump is not turning on and im begining to get pissed injectors are good main relay is good fuel pump tested and good
i have swapped out the ecu for the stock one and a p14 and still no difference the ecu fuses are good even replaced just in case
im still getting nothing at all i have swapped outthe dizzy twice still nothing
i need to know what pin the ecu power is and whatthe diagram of my ecu wiring should be also if anyone else has anything they can throw in as an idea b4 snow falls again please help me out im close to callin it quits and buyin a common car and not modding it this is rediculouse
