squeels when shfiting
    ok so a couple days ago my car started squeeking when i take off and when i shift. im not barking the tires and its not the belts but when i take off it sounds like im chirping off the line and the same whenever i shift in any other gear, it sounds somewhere around the tranny...any thoughts what it is?
    Automatic?
    Its hard to distinguish what sound it is because there are lots of things in your engine that can squeal. I know you said its not your belts, but i'd check them again. Too tight or too loose can make it squeal.
      SOunds like a manual. Could be TO bearing. BUt can you be a lil more specific?
        when i was playin with the shifter i had the cable on the shifter and the other end of the cable was layin on the floor (inside my car). i was moving it around and i hear this sqeak noise. i look at the rubber when i move the gear it suck in air and fart it out making a sneak noise. maybe that's what ur hearing ?
        DEFJAM
        MY RIDE ON CB7 DEFJAM on 93
          yeah its a manual and it only does it when im driving solftly it doesnt do it when im on it. i just replaced the cluutch about 3500 miles ago (so its broken in) with a XTD stage 2 and an OEM throwout bearing straight from honda and the flywheel was resurfaced. its a really high pitched really quick chirp that sounds like im spiniing the tires off the line and when i shift. and it sounds like its coming from the passanger side when the windows are down and im driving it.
