ok so a couple days ago my car started squeeking when i take off and when i shift. im not barking the tires and its not the belts but when i take off it sounds like im chirping off the line and the same whenever i shift in any other gear, it sounds somewhere around the tranny...any thoughts what it is?
squeels when shfiting
SOunds like a manual. Could be TO bearing. BUt can you be a lil more specific?
when i was playin with the shifter i had the cable on the shifter and the other end of the cable was layin on the floor (inside my car). i was moving it around and i hear this sqeak noise. i look at the rubber when i move the gear it suck in air and fart it out making a sneak noise. maybe that's what ur hearing ?
yeah its a manual and it only does it when im driving solftly it doesnt do it when im on it. i just replaced the cluutch about 3500 miles ago (so its broken in) with a XTD stage 2 and an OEM throwout bearing straight from honda and the flywheel was resurfaced. its a really high pitched really quick chirp that sounds like im spiniing the tires off the line and when i shift. and it sounds like its coming from the passanger side when the windows are down and im driving it.
