Well my VSS is being a lil bitch and its annoying me. First of all this all happened after i swapped in my h23 trans when it had the F22A trans it was fine. Well we changed two of that main long shafts (from my old one and the h23 one) 3 VSS and knowing two of them work, and Checked the wiring which is unscathed and just fine. The only other thing that my buddy came up with was the countershaft which is inside the trans but he says it looks like where they are meshed and if that part was messed up it would cause some driveability probs which I am not having. So my final question is would the gauge cluster be a good culprit? All my CEL lights, tach, temp, fuel all work except for the speedo. So Im just wondering if it could be just my gauge cluster being a lil bitch. Thanks in advance for the help.
VSS Question.
VSS Question.
IA 08 Sunburn Victim #1Tags: None
Yes it is throwing CEL 17. Alldata says to check the wiring if not the VSS unit itself and something else I forgot. Ill check the voltage to the cluster whenever I got time thanks. I recently pulled of my Blitz power meter which was spliced right into the speedo gauge. So dunno might have to check it out even though it was still doing it before I took it out.
Well, if its throwing code 17 .. thhhhats the booger .. lol .. bad vss ..
Alltho .. if you had splices, and say it was doing that before you took out the power meter ..
Hmmmm .. I dunno man .. test each wire?
The manual vss units are different then the auto units .. you couldnt have the wrong one in .. no?
I only know that they're different .. whether they fit or not .. I have no clue .. prolly not
Sucks when wiring issue's arise ..
Tomi
Originally posted by TypeGif just your spedo didn't work, it wouldn't throw a CEL. later.
If its my countershaft which is what its looking more like I might see if this trans is still under warranty and buy another...*** this sucks.
