hmm.. my friend's accord is having problem. we fill this up completely with coolant because we believe water is bad for our engine.. why? water and metal dont mix.. they create rust.. notice ur brake plate turn brown when u dont drive it for a whole day? ... so. we avoid putting water. even tho people say it's okay but we choose this so let's not talk bout that part now. the radiator is full. but.. the car still overheat afta driving it for longer than 30 mins. the worse part is we all believe it was the thermostat.. but it been replace not too long ago. includin the waterpump. either of those hose throw any cooolant thru.. the bottom nor the top. but when the thermostat gets hot.. it open up to let some coolant in or out.. (top part). i noticed the tube get flat skinny when the thermostat open. i grab on the tube, i feel small amount of coolant rushin out and getting really hot but when i look at the temperature it's on normal. but it doesnt look normal. after driving it for an hour the engine begins to heat.. not getting enough coolant to keep it cool down. what could this be? both tube are flat like there no coolant in it... i did open the thermostat to take out air from the engine. they flow nicely. but it seem to be SPITTIN the coolant out then pouring out. and i look under the car cuz i was reving the engine to heat up and noticed not one drop of coolant spill on the floor.
what could be the problem?
