Throwing up codes like gang signs
    OK so my CEL has been on for a bit and here are the codes I got:
    7- TPS
    14- IACV
    20- Electrical load sensor
    41- O2 heater (w/e)
    Do I have to replace the TPS and IACV to clear the first two codes?
    Originally posted by lordoja
    did u replace the tps, if so did u adjust it to proper specs,
    is ur idle surging, if not then make the the iacv is plugged in all the way
    as for the other two i am not sure, try resetting the ecu and see what comes back
    Members Ride
      I know for a fact my O2 sensor is good...the EL...I dunno...
      But I recently replaced the TPS; I guess tomorrow will be spent calibrating it. As for the IACV, ever since I changed my A6 plenum for the H23 it's been surging like crazy. I disconnected it to see if I could drive w/o it and the CELs started. I'm hope I didn't ruin the IACV...I'm gonna clean it and calibrate the TPS tomorrow.
        The uk honda page has sections for testing when you get these codes. Time to get out your multimeter.
        TPS testing, http://media.honda.co.uk/car/owner/m.../400/6-176.pdf
        http://media.honda.co.uk/car/owner/m.../400/6-178.pdf
        EACV,
        http://media.honda.co.uk/car/owner/m.../400/6-194.pdf
        http://media.honda.co.uk/car/owner/m.../400/6-198.pdf
          for the iac, u might have a coolant hose backwards, this happened to me also, as soon as i switched them, the surging went away
          Members Ride
            That's what I'm thinking as well...on the FIV though. My cold idle is like 2000RPM
