What the hell is causing my idle to get all funky after i drive with the ac on ? Ok so my car idles fine each and every day. When i go to use my ac the idle kicks up a bit and thats fine and normal. My problem starts when i turn the ac off the freaking idle jumps to about 1300 rpm and stays there. Some times it goes higher close to 2k rpm's if i drive more. Anyone know what controls the idle when you turn the air on ?? HELP !!. Some times i have to let it sit for 15-30 mins before the idle is back to normal.
![Confused](http://www.cb7tuner.com/confused.gif)
