valves?
    valves?
    I just did a A6 camshaft swap on my A4 and i did a valve adjustment too. Now my car ticks really loud when its cold, and it ticks louder then it used to when its hot. A mechanic helped do the job, he worked at Toyota for 5 years, so i dont think its a faulty job by us. Does anybody have an idea of wut it may be?
    1991 Cb7 Coupe 5 Speed--SOLD
    2002 Nissan Sentra SE-R Spec V-- SOLD
    1994 Acura Legend GS
    Car Pics
    Recheck the valve clearance. Not saying its bad but Check the obvious first
      ^^^ what he said
      Not my fault my dick only fits magnums.
      Why drink and drive when you can smoke and FLY?
        adjust to the minimum...
        so if the range is .009-.011
        make it .009 and the engine has to be at least sitting for 24 hours
          did you do it correctly and use the correct specs? did you do it in the correct firing order?
          where did you measure? hopefully it was between the rocker arm and valve stem.
            Yea i m going to do that. The only problem is that i m driving my car to Montreal on friday and back. I live in maryland, so thats like 1200 miles the whole weekend. Will my car be ok? Like is it something i need to do immediatly or can i wait till after my trip. Cuz the mechanics at the honda dealership said that ticking is normal on older accords. Dont know if thats true or not
            Car Pics
              its normal yes, only because things wear out over time. it should go away, or mostly go away after and adjustment.
              and no, i woudlnt drive it with how loud you said they are.
                did u do the adjustment when the motor is cold??? I redo them again if i was u
