Wondering if anyone knows the approximate cost of getting a f22a4 engine rebuilt? I won't be able to do this myself since I don't have time and would probably mess something up lol. I'd rather get it done right. Any help would be good, thanks.
Estimated cost for a F22a4 rebuild?
Alright, thanks. I just wanted a good idea of what I'm going to be spending. I also just found this site http://www.rpmmachine.com/engine-reb...ts-honda.shtml think it'd be best to get the "Major Engine Kit" and just do it myself?
www.importperformanceparts.net
Has same Topline engine kits for cheaper.
If you have the downtime available and nothing better to do after work or on weekends, buy yourself a Haynes manual or Helms manual and learn!! Why not? You're doing a stock rebuild, no real aftermarket performance parts so you don't have to deal with tuning issues to get your engine running decent. Rebuild it and learn man, just take your time and do things right, use common sense and you'll learn a heck of alot.
In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
Bumping this thread for future researchers.
I'm currently doing a stock rebuild.
this is what I'm in so far..
COMPLETE gasket set(every single gasket on the engine) from ebay: $52 shipped
ACL complete bearing set: $60 shipped
Head resurfaced, cleaned, 3 angle valve job, new seals: $120
OEM Honda rings: $133 shipped
I still have to buy
engine oil/filter
transmission oil
assembly lube
new o2 sensor
lots of cans of carb fluid(used for cleaning surfaces)
spark plugs
spark plugs wires
cap/rotor
and random other parts.
Total cost will be around $600 most likely.
If you had a shop do it, it would be closer to $1000.
I haven't totaled it all up, but my complete rebuild, which included bore and hone, new pistons and rods, all gaskets, and so on, was close to $1000. Also, don't forget the timing belt and water pump while you're in thereOriginally posted by DoctorCipher...the beginner forum was created to provide a place for all the stupid ass questions to pile up and fester, kind of like huge globs of mayonnaise left in the sun for weeks at a time.
and then you probably need an engine stand and specialty tools...another 300 easy
I still have to buy
engine oil/filter
transmission oil
assembly lube
new o2 sensor
spark plugs
spark plugs wires
cap/rotor
what about bottom end,
What about crank shaft, will that be rebalanced?
your pistions will u b keepin the ones u have**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7u can rent the stand and mayb of the other tools needed for the job
ok that was top end
I posted bearings and rings. I'm obviously not replacing the rods/pistons. There's no need to.
Theres a place i forgot wherem but u can buy rebuilt engines for cheaP**Blk Housed Slut Crew Member #1**
