I have a really annoying loud click in my front left suspension...methinks it's the LBJ because when I did that axle I tore it up with the pickle fork about a year ago, and it's been getting progressively worse since I changed my suspension. Is it easy to replace or should I just pay to have it done? I need an alignment anyway.
Lower ball joint replacement?
Upper balljoint I think.
Watch my vids. Does it sound like that?
http://www.cb7tuner.com/vbb/showthread.php?t=56972
Hmmm...nahhh that's not it. Mine kinda pops when I'm braking, and sometimes when I turn standing still. I'm gonna get it looked at, but I'm almost certain it's the LBJ or something radius rod related...
Originally posted by gloryaccordyHmmm...nahhh that's not it. Mine kinda pops when I'm braking, and sometimes when I turn standing still. I'm gonna get it looked at, but I'm almost certain it's the LBJ or something radius rod related...
Wow, yea I'm definitely taking it to a shop. It might be my radius rod though...when I did my crossmember only one of the bolts on the LCA went through. I don't know if it's the bolt or the arm, but I could see how that would cause a problem as now there is a degree of freedom for rotation there that wasn't there before. I'm gonna see what the mechanics say.
Originally posted by gloryaccordyWow, yea I'm definitely taking it to a shop. It might be my radius rod though...when I did my crossmember only one of the bolts on the LCA went through. I don't know if it's the bolt or the arm, but I could see how that would cause a problem as now there is a degree of freedom for rotation there that wasn't there before. I'm gonna see what the mechanics say.
Originally posted by HondaFan81You're talking about the radius rod and how on the lower control arm end of it, it has 2 bolt holes for the 2 screws that fasten the radius rod to the lower control arm. So you're saying only 1 of them lined up. Well, keep in mind that you are fighting the radius rod bushings and lower control arm to install that anyhow, it's a little fussy in normal circumstance. I'd try again and use more force to try and line it up and if you can absolutely not, then yea...something may be bent from your previous accidents, etc.
Originally posted by h22sparklenah it happened when he fucked with the suspension from the last time i told him not to and that to wait for me to change it for him but anxious glory just couldnt wait to re-adjust the suspension.
Nah it's definitely from when WE did the driver's side axle almost a year ago, and tore up the boot...I've had this noise problem since before I did my motor mounts
Originally posted by h22sparkledamn well ill be watchin when you get it changed just to see how i can do that. i never changed the lower one before.
Well, it depend on your previous lower balljoint condition. Mine was really messed up and it took me almost two hours to change the lower balljoint. I really recommend you to follow the procedure from honda service manual. I did not follow the procedure, so I ended up taking off the whole knuckle. It was really depressing. My dad's friend told me that I should have taken off the brake caliber and the rotor in order to use the balljoint press, and it was true. I ended up hitting it until it pop out from the knuckle and did not use the balljoint press. You need a friend to hold the knuckle.
-Tools that you need is ball joint press, [the C chaped one] (you can borrow it from autozone).
-fork (?something I forgot the name), to separate your lower balljoint from front lower arm.
Thast was my experience and it was a very sunny and hot day at the time. I hate it
