does any one know why the f22a6 has more power then the f22a1, like is it an easily changable part that i can swap out
f22a6 to f22a1
A6 has a dual runner intake manifold with butterfly valves that open at high RPM, as well as a split port exhaust manifold. In order for you to "convert" your A1 to an A6, you will need the exhaust manifold, intake manifold, ECU, and butterfly valve solenoid. Not to mention, A6 cars run a higher fuel pressure than the A1/A4 cars do. If you are just looking for more power, there are much more cost effective ways to gain 20 ponies.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
tell me about this exaust manifold....
the cam shaft are differnt as well.
the f22a6 is said to be at like 140 and the f22a1 at 125 i thinkWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
The exhaust manifold? oh, come on ztech, you should know this. The A4 and A6 have that split port manifold that kinda looks like an aftermarket header. The A1 on the other hand has a conventional cast iron manifold which collects into one single pipe.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
nooo i always thought the a4 and a6 header was exactly the same?? can u draw it or something?
hahah hey!! im learning too!!What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
a4
a6
i see it but i dont see a purposeWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
i thought he said the a6 and a4 was differnt. they are both 4-2-1What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
hey sorry for the resurection but this has been discussed with fizz in a thread he started, does anyone know for sure whether the a4 or the a6 manifold has better gains? Reason I ask is cuz I have an a6 manifold but if the a4 is better I'll get one of them instead
Originally posted by fizzbob7the a4 HEADER is superior to the a6 exhaust MANIFOLD (in my opinion)....manifolds never outflow headers when they're mostly equal in design....both are 4-2-1, but the a4's header lacks all that casting flash that a CAST MANIFOLD will give you.....it's smoother, should flow better and should outperform the a6's manifold......albeit a couple of hp or so, but still, until i see proof the a6 manifold is better than the a4's header, i won't believe it
i have one of each (a1 4-1, a4 4-2-1 header, a6 4-2-1 manifold) and i've settled with the a4's header
Very interesting.
