!HELP! H22 Transmission problem... bent fork, bad sync, etc. !HELP!
    Well, i had a shop tear apart my tranny today and they found out why i can not get into reverse. The 5th gear sync was worn, hub and sleeve (not sure if thats what he said on the phone), and the fork was bent. My other syncs showed signs of wear as well...
    Well, I was wondering what you think my best options are. I called gearspeed and a sync set was 275 from them. If i get the half set (3,4,5) then its like 150. I was wonderin how much the 2nd gear sync runs from Honda... also what about the fork and the other parts? Should I find a donor tranny? HELP, i wanna get my car rollin again!
    Formerly 91AccordExR33
    11.68 @ 127mph
    417whp/375wtq
    Sold: 8/2016
    why dont you just get another tranny?
      i dunno....h22 tranny seems a lil pricey dont u think....then swap the quaife, etc....
      11.68 @ 127mph
      417whp/375wtq
      Sold: 8/2016
        lee, by the time you get your tranny to where you want it, it would have been smarter just to buy a tranny with lsd in it. and less work for you.
        (129)Transactions and counting
          should i just swap the LSD into a H23 tranny?
          11.68 @ 127mph
          417whp/375wtq
          Sold: 8/2016
            yes, that'd be awesome. then, you could send it to me for free.99.
              dont be a fool send it to gearspeed and have them do the whole shit with a warrantee
                im leaning towards putting the quaife in the h23 and then buildin up the h22 with gearspeed....tho i dunno if i can fund that....
                11.68 @ 127mph
                417whp/375wtq
                Sold: 8/2016
                  found a h23 right now....may jump on it and put the quaife in there
                  11.68 @ 127mph
                  417whp/375wtq
                  Sold: 8/2016
                    well the tranny was not a h23....so
                    i ordered the 5th gear sleeve set, shift fork, and gear-speed coated 1-5 syncro set....this better be worth it
                    i actually found out that the bend fork was common on some of the h22 trannys and it was a manufacter defect...
                    TSB REPORT
                    thanks to Preludeonline.com
                    11.68 @ 127mph
                    417whp/375wtq
                    Sold: 8/2016
