i know i burn oil when it is cold at low rpms..say engaging into 1st from a stand still.
the reason is puffs of blue smoke comes out and it smells pretty bad (well, obviously) umm, if i remember right i accidently filled it over a quart and it was to the low indicator marking when the engine was warm emaning it burned over 2 quarts of oil in two weeks or less than 500 miles?
i checked the spark plugs each time and they are pretty damn clean. other than running a bit lean the car runs fine and smooth as heck.
idk, the valve stem seals were replaced when i had the h23 head resurfaced. so idk why those should be the problem unless the valves are worn out to the point where oil is getting past them anyways. my antifreeze is the same level so it isnt mixing/eating any of that.
the block has less than 3k miles because it was brand new and like i said before it pulls hard all the way to 6k.
bah, this kinda sucks. i hope it doesnt get worse, should i change the oil to some thicker oil+oil additive?
i bought a gallon of GTX 10-40 and i have oil additive...change b4 it gets worse?
