Okay Listen to BOTH videos. Sorry they are short. Turn up volume and listen. Look at the rpms. What's wrong here?
mr. h22 sparkle said that my timming was off. I used a craftsman timming gun but you can't set it. I just shot the light in it and move the distributor so that the white mark was lined up with the little V groove. But he said I need to get a gun that has the dial and set it to 15.
Do you think this is why?
Once this is fixed I should be golden. Im going to get this gun with the peice to adjust tommrow I hope, and some coolant. Since you guys said water is bad? so yeah. and fix the little leak at the firewall.
The hose going from the engine to the firewall of the car the right one is leaking. The metal tube kinda bent and yeah Whats the best thing to use around it?
First vid
engine bay sound...
First vid
engine bay sound...
