Last few problems, overheating? Speedo? and gas cable...
    So I fixed everything but these things.
    The speedo on my car doent move at ALL when im moving. why?
    Also i filled the radiator with leaks with water and it seems to be overheating.. anyone know why? I thought u could use water?
    Also the throttle body cable.. well those 2 12mm nuts are all rusted off and only one side will go loose. how can i get it on? since i cant move the nuts to set it right? LMK thanks
    can I get some responces?
      vss for the speedo
      you need a 50/50 mix, water boils at 100 degrees. It prob doesn't take long for the engine to exceed that temperature
      I'm guessing you need a new cable, either that or cut those nuts off
        1. Vss plugged in if it is might be broken throwing a CEL?
        2. Pressure test it prob somewhere else leaking yes you can use water.
        3. Get some PB blaster and it should let it loose a bit.
          did you bleed your cooling system properly. if you got air in there it will cause overheating.
          The CB9 has been reborn into a CB3
          Members Ride - see my cb3 here - DOHC powah
          Check out my JDM F22B swap
          Watch my CB7 video
            my speedo didnt work, nor did my tak, nor did my fuel or temp guages. i got a new cluster and the tak and speedo work. but the fuel and tem still dont. i dont know whats going on haha. make sure you use 50.50 coolant/water split. urm. water pump maybe.. thermostat.. leak... thats all i got. not much of a contribution but i tried lol.
