Engine tapping...
    Engine tapping...
    Yeah...
    Just yesterday I started noticing a tapping comming from the engine whenever I start the car and when I accelerate. Not just a low quiet tapping. It's more of a semi loud tap tap tap that gets faster with higher RPM's. Me thinks it may be a busted something or other in the engine but I can't be sure. All I know is the RPM's are a teeny bit lower then usual and there's not a lot of power. Might take it to a mechanic today but I'd like to know if you guys knew what it could be. Thanks...
    Might be your motor mounts,detonation,messed up cylinders. check your mounts first though.
      check mounts though.
      but im thinking valve adjustment is needed.
      Retro!
      Hater
        check the oil man. sounds like you got some friction going on that you shouldn't have.
        My Cardomain
        Current Score: Cops - IV Me - V
        Quote of the moment: "The problems that exist in the world today cannot be solved by the level of thinking that created them."
        Albert Einstein (1879-1955)
        Simulation Racing Thread i.e. PC, PS2 & XBOX
          yup valves too may need adjustment like he said.
            valve adjustment first...then check other things later.
            Finally Up and Running. Numbers to Follow. Check my MR
              and pray its not detonation while your at it...doesnt really sound like it is but still pray.
                If it's something unholy like detonation would it be very noticeable like lack of power or heavy vibration? It's still got the same get up and go although I'm scurd to push it. It idles a teeny bit lower than usual but not a whole lot. I'm getting my mechanic bud to look at it so I just wanted to make sure I give him somewhere to start looking. Thanks a lot you guys/gals...
                  detonation isn't going to be as loud as he is discribing it to be. Even so, if it is detonating, the knock sensor should immediately pick up on it and the ECU retards the timing.
                  00 Jeep Grand Cherokee 4.7 V8 4X4
                  92 Honda Accord LX
                  95 Honda Civic CX
                    It's pretty loud now that I rode with the stereo off, duh me. Anyways, it also makes that sound when I start the car and accelerate, otherwise you don't even know it's there. I'll find out soon enough what the problem is. I just hope it's nothing overly serious...
                      Yup you most certainly have valvetap time for a readjustment.
                        I know I'm getting repetitive, but would this problem have come from bottoming out? I think that it may have caused it but again I am not mechanically inclined. As I was pulling out last night from my step moms driveway I bottomed on the curb and the next day I noticed it...
                          No not that ive heard off ANd your speakin to an expert who bottomed out quite awhile. nah i think i think it just goes out of adjustment how many miles?
                            Heh, I hear you. Anyways, it's got a nicely sum of 187,300K on it. I was hoping that it also didn't stem from a dented oil pan problem. I GREATLY appreciate your input as well...
                              Dont mention it cb7's live forever dude just make sure you take car of it
