Parts sites with Honda part numbers, which ones?
    I'm trying to use the Honda part numbers to verify switchable and same parts. Which internet parts sellers or catalogs have the feature of using Honda manufacturer's parts numbers, even if the part is not available? Nothing is more frustrating than to find no part number only because the part is out of stock.
    i use hondapartsdeals.com
    1993 CB7
    2001 BB6
      Try slhonda.com
        Thanks, bresk8r87 and deckeda. I went to those sites and it is a help. Do you know if those first 5 numbers designate the part, with the next 3 letters/numbers combination designating the manufacturer, and the last 3 letters/numbers combination designating any changes?
          Sorry, I'm lost.
          San Leandro shows actual Honda part numbers when viewing search results --- same as your local dealer. Search for the same part on a different Honda; if it's the same part, it's the same part ... is that what you mean?
          You can do the same thing, indirectly, with Majestic (http://www.hondaautomotiveparts.com/...artsSearch.jsp)
          You can search Honda part #s (but you have to know what they are) but the results come back with only their inventory #s.
          Hope that helps.
            try www.bernardiparts.com . I just bought a couple parts from them this week and they are cheaper than some other honda part sites.
            1993 Accord LX - Sold
            93 BMW 525it - SOLD
            92 Accord EX Sedan - SOLD
            2000 Accord Coupe - Traded-In
            2003 Accord V6 6spd Coupe - Sold
            2001 Honda Civic Ex - SOLD
            2013 Chevy Traverse LTZ - Kid hauler
            2003 Acura Tl 3.2 - Daily Commuter
              Originally posted by deckeda
              Sorry, I'm lost.
              San Leandro shows actual Honda part numbers when viewing search results --- same as your local dealer. Search for the same part on a different Honda; if it's the same part, it's the same part ... is that what you mean? ...
              Sorry, I was trying to inquire, since I don't have the answer.
              Here’s what I’m trying to do. I am trying to find compatible or interchangeable parts from different years and/or models. For example, we know that the front (steering) knuckles for the Accord years 1990 thru 1997 are interchangeable, and they differ for left and right.
              Accord 1990 front right knuckle part number is 51210-SM4-J53
              Accord 1997 front right knuckle part number is 51210-SV4-J50
              And another
              Accord 1997 front right knuckle part number is 51210-SV4-J52
              Does anyone know Honda’s numbering system? Is the SM4 and SV4 indicating a different manufacturer? Or a modification?
              Is the J53, J50, and J52 indicating different manufacturers, or modifications?
              And of course, the LEFT knuckle is a different first set of 5 numbers, 51215-xxx-xxx.
              I’d be happy if someone can explain it to us.
              Thanks.
                I see what you're saying now, but I don't know if it will give you a real-world answer. Take for example the knuckle part #s you have there.
                They are different numbers, and maybe/probably-but-not-necessarily different parts.
                What I mean is, if your theory about the manufacturers is true, then they could be the same exact part still. But even if there was a small change (the '97 might have an ABS fitting lacking on the '90 for example) that doesn't rule out its use for somebody if that difference isn't important or noticeable to them.
                There are a few folks here that work at dealers --- they might know, or you could ask your local Honda dealer ... those knuckles would be an interesting one to ask about.
                In the short run you may just want to ask on a case-by-case basis about a certain part to get the real world skinny, regardless of part #.
                  Thanks for the Bernardi link. That one atleast has a bit more intelligence to it and notes discontinued parts.
                  '92 Accord LX Sedan--Bordeaux Red Pearl --OEM--279k Daily Driver
                  EX Lip & Alpine OEM single CD Player. No more useless pocket!
                    first set of numbers is the part designation
                    2nd set is model related
                    3rd set is the revision of the part, as in a 1991 pt3 ecu may have a diff program than a 1992 pt3 ecu.
                      Thanks. Now it makes more sense to me. I do realize that slight modifications might still allow interchangeability. So it still does boil down to practical knowledge and experience. Thank you to all.
