i have this brown thick liquid running thur-out my whole car like its took place of my anti-freeze. my overflow bottle leaks it and it all thru my radiator......i flush it out but it came back again...What is this cause from?
What's Wrong With My Car?
I hate to be the bearer of bad news, but that liquid is motor oil mixed with the coolant. Could be caused from a cracked block, or head gaskets. STOP driving the car, and get it pressure tested to find out what the cause is. Maybe the best time for the h22 motor swap.
Disregard females, acquire currency.
My 2003 Nissan Maxima Members Ride Thread
DIY: HOW TO POST PIC(S)
Originally posted by CustomLowzI hate to be the bearer of bad news, but that liquid is motor oil mixed with the coolant. Could be caused from a cracked block, or head gaskets. STOP driving the car, and get it pressure tested to find out what the cause is. Maybe the best time for the h22 motor swap.
Damn my car is auto, but every couple of dayz my trans fluid dissappears no leaks but the tranny takes a long haul to switch gears, and i refill and then it gones, could it be the tranny fulid mixing and how does that happen?
Blown headgasket stop driving the car, drain the oil, drain the coolant, change the gasket, resurface the head by a presentable machine shop, torque it back down to spec,fill it back up with oil in the right spot,fill it back up with coolant in the right spot,bleed the coolant,. Start up the car pray that nothing happens bad, Done.
Originally posted by h22sparkleBlown headgasket stop driving the car, drain the oil, drain the coolant, change the gasket, resurface the head by a presentable machine shop, torque it back down to spec,fill it back up with oil in the right spot,fill it back up with coolant in the right spot,bleed the coolant,. Start up the car pray that nothing happens bad, Done.
