power window not working
    my driver side switches to roll the windows up/down dont work....my passenger side works fine...im thinking that its the switches? should i replace the switches? im pretty sure the window regulator is fine...just need someone elses imput. thanks
    if you used two different switches on the same window and only one worked, i'd say it's the switch. just check the harness to make sure it didn't come unplugged on the backside. later.
    Avoiding dirt at all costs
      Absolutely the switch or an unplugged connection.
