okay everyone with h22's check in
    I wonder where should my fuel pressure should be at idle and at wot. First off my vacuum idle fuel pressure with the hose on the regulator is at 46@idle and i took the vacuum off the regulator its at 56 is that good or bad just double checking. I think im runnin too rich
    Okay i bumped it down to 40psi because of the fact that i think the shit bumped its way up on its own with the b&M fpr i have i touched the shit with a wrench and it was already loose which explains why i killed my last o2 sensor and wasting a shit ton of fuel for no reason..
      Thats good. Tells you your regulator is doing what its supposed to do. But might want to check a manual on the fuel pressure Im not sure of the spec. IF your running rich back it off a lil but not too much.
