No ignition output signal
    Well same problem I've been having for the past couple weeks now, so my car has been sittin at home until i come home on the weekend to try and mess with the POS. But ne way I have no ignition output signal coming from ECU to my distributor. All my fuses are fine, I've replaced quite of few things thinking that was the problem (new distributor, ignitor, coil, main relay, switched ECUs, replaced all the under hood relays) And I still just can't seem to get any spark. I have power from my black/yellow stripe wire from my ignition switch to my dizzy but i have no power at all from my ecu to my distributor which is the yellow/green stripe wire. So i'm not gettting power from somewhere, does anyone know where this thing might be gettin power from? My front coolant temp sensor I think thats what it is has no power coming to it. the green one on the front water neck on the head. Or could it possibly be my TPS would either one of these stop me from getttin spark? Or if anyone has had this problem before, any help would be appreciated. BTW the car is a 90 EX 4 door/ 5 speed, w/ a h23a1 and the f22 trans.
    Previous cb7members ride thread
    86 Nissan d21 in the workshttp://www.cb7tuner.com/vbb/showthread.php?t=155292
    TSM Garage: Honda/Acura, VW/Audi, and Subaru performance and maintenance work.
    Contact:Ben Cell: (302) 898-1840
    check connection to starter from battery?
      check the bottom "dis" wires= "your wire harrnes "dis" connection" they tend to come off or losen up and make no contak
        I'll check the connectors for the distributor again but I didn't see anything wrong with them. And all both of my wires on my starter are good. I mean the car turns over with no problem I just can't get any spark.
        Thanks for the suggestions, I'll go over everything again this weekend for the 1000th time
          I GOT IT! FInally after liek a month, i rewired that SOB. I just gotta check and fix my ignition timing since i think its was off now since i switched dizzys,
          But its got spark now finally
            Great! Good news!
              Not quite, Ignition timing is way off b/c the car won't fire up right now, any one knwo how i find out what my ignition timing is with out the car running, because i think its just way off
