change my thermostat ...cant wont start now....
    ok guys , i have change my thermostat cause my cause was heating too much
    i change it , now the car wont even want to start
    the car will crank but without doing any fire
    i have notive that the fuel pump will not start at all and that the main relay wont click either
    so i thinks its the main relay but... when i turn on the key to position 1 , all the light will get on normally except the CHECK ENGINE .... thats strange....
    any idea? if the main is dead , will this happen??
    Check your t-stat ground.
      where is it?
      but even if they was a problem with the t-stat , the car should be running anyway , no???
        Originally posted by RaccorR
        where is it?
        no, it's the ground wire that connects to one of the thermostat bolts....if it isn't there, it won't start, it's that big of a deal
          holy shit , you were right , i didnt saw that ground when i firt took off that 10 mm bolt , my engine bay is sooooooooo dirty
          BIG THANKS FOR THE HELP
