Before I even begin. I searched, i found and tried what i found. Here is what I have done. Took of the IACV valve and cleaned the shit out of it, its clean...replaced O rings in it. That did not help. Took of the FITV, cleaned it and tightened that plastic screw looking thing....replaced O rings there and put it back. Still is doing the same fuckin thing. Flushed the coolant and cleaned the throttle body and ts still doing it. Im out of ideas guys
Bouncing Idle, WTF?
Bouncing Idle, WTF?
h23a3 cb7 turbo sold
FS: 1 Piece JDM Headlghts blackhoused
My Members Ride !
New ride
'07 GTI Mk5 6spd
Tags: None
Did you bleed the coolant after you did it?
Its a 12mm bolt/screw thing on the bell shaped housing...Happened to me, its like the car has hickups. Where in philly are you? do you go down to the races much? PM me, Maybe we can meet up sometime with other Philly peeps
-Lam
*edit - I just saw you Members Ride thread and I noticed you have the F22. I was refering to the H22 so idk if its the same
Originally posted by prodigymbBefore I even begin. I searched, i found and tried what i found. Here is what I have done. Took of the IACV valve and cleaned the shit out of it, its clean...replaced O rings in it. That did not help. Took of the FITV, cleaned it and tightened that plastic screw looking thing....replaced O rings there and put it back. Still is doing the same fuckin thing. Flushed the coolant and cleaned the throttle body and ts still doing it. Im out of ideas guys1992 Accord Coupe 5-Speed
ill try to bleed the coolant again, there are no vacuum leaks. how can i check the functionality of the pcv valve?h23a3 cb7 turbo sold
My Members Ride !
New ride
'07 GTI Mk5 6spd
bled the coolant again, no bubbles. still the same fuckin shit. is it possible that the IACV is bad...the electric part of it?h23a3 cb7 turbo sold
My Members Ride !
New ride
'07 GTI Mk5 6spd
or just open the radiator cap, turn on car, and refill it slowly. squeeze the rad. hoses as you fill it up. it takes a while, but it gets the job done.
you will know when there are no more bubbles in your radiator; no bubbles will come out when you squeeze the hoses.
Originally posted by prodigymbill try to bleed the coolant again, there are no vacuum leaks. how can i check the functionality of the pcv valve?
shake it, if it rattles it is most likely ok, but you might as well buy another one they are like $10.Also, pinch the egr vacumm line and see if it stops fluctuating.
ILBBPeople I have dealt with in this board- Smseagren83,d112crzy, Idrivealude, aznpnoyracer, wed3k, dinertime, HF22T, MRX, Dc2lewd, yeamans17, bruno8747, tn_accords, king james, starchland, yardiexd40
Mk3 Supra Member #2
Originally posted by DarkShadow707The world needs to be reset.
Originally posted by Ilikebigbuttsshake it, if it rattles it is most likely ok, but you might as well buy another one they are like $10.Also, pinch the egr vacumm line and see if it stops fluctuating.
ILBBh23a3 cb7 turbo sold
My Members Ride !
New ride
'07 GTI Mk5 6spd
This fixed ! My cam was the issue and here is how i fixed it !
http://www.tuneruniversity.com/forum...ead.php?t=1740h23a3 cb7 turbo sold
My Members Ride !
New ride
'07 GTI Mk5 6spd
well, guess what.Since my f22b dohc didnt come with that starting valve thing, i installed when i put the motor in.I decided to take it off when i read this and while i was there i discovered that my pcv valve hose is torn.So i put the block plate back on and put a new pcv hose on and guess what, cold start started easier and it didnt strugle to find idle the fist few seconds.Warm idle and my mirror (that i have duct taped on) doesnt shake anymore and no more dashboard rattles!!so i dunno know what it was but a combo of these two and my car is not gonna be so annoying at stoplights anymore.yay!!!
oh, and the pcv IS suppose to make some sort of a noise when you shake it...if it doesnt, replace it.It's either stuck open (which i doubt cause your idle is fixed) or stuck closed...which is bad...
Mk3 Supra Member #2
get a haynes manual....go through the trouble shooting for erratic idle. ok so look for this flathead type screw on the throttle body i believe...its an idle adjustment screw, adjust it down i believe or whatever you gotta do to make it stop. the screw should be near some gray vacuum lines towards the firewall as i recall...i had erractic idle for like a week, then adjusted that screw and it stopped...let me know if you get it
-seanMembers ride 15.927 @ 86.76 (f22a1)
Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
Arcadia Green Crew #10
Originally posted by ShehzadaSo what did you do? Blocked off the 2 ports of the FITV? Mine is a F22A1 and what do I do with the coolant hoses?
quiet a productive thread everyone!!!!Last edited by prodigymb; 07-11-2006, 10:14 PM.h23a3 cb7 turbo sold
My Members Ride !
New ride
'07 GTI Mk5 6spd
