I just wanted some advice before I start tearing my engine apart. The problem is that my car smokes any time its cold and at high rpms. Not just a little smoke, I mean like a James Bond smoke screen. At first I was thinking rings or head gasket, but I did a compression test monday. The reading were
#1 - 200 psi
#2 - 210
#3 - 210
#4 - 210
So after getting these numbers I didn't think too much anymore that that was the problem. I noticed when I took the #4 spark plug out that it was totally saturated in oil. I looked down in the chamber and there was oil everywhere. So hooked everything back up and did a timing check. Timing was at like 17 1/2 so I bumped it back to around 15 - 15 1/2 advance.
I was thinking that maybe the valve stem seals are allowing blow by. What do you guys think could be the problem?
Also an update on my h22 build-up. I completely ran out of money as to what I was building. Times got hard, so I ended up selling it all. $4500 in parts sold.
#1 - 200 psi
#2 - 210
#3 - 210
#4 - 210
