Yesterday I tried using silicone around the seals, today it rained again and I opened up the trunk and about a cup of water leaked out... Can this be because of the flushmount spoiler? How do I fix it?
Trunk still leaks ALOT.
There's only a few major places the trunks leak...I've been on a quest myself for this.
They leak:
- Tail light gaskets
- Antenna drain tube
- Rear glass molding clips
Your flushmoutn might be a place where it would leak...but I highly doubt it would leak as much as you're saying it would leak.
I'd recheck those areas and then hit your trunk area with a hose while someone's watching for leaks.
def follow these guys ideas. i had a major leak and i found out it was the chrome trim clips or lack there of. i found out 2 clips were missing, just replace clips and fill edges with silicone. also what i found helped was to go inside the trunk and put silicone around the underside of the clips. hope u get that nasty leak fixed
