Tachometer, dash wiring
    Ok i was searching, around on this thread as well as the internet, but there was to many mixed up results. here is what i am trying to figure out. if you have seen the pictures in the Full Race to be thread, you will see the tach that i have. the pathetic wiring across the passenger side wiring which is going between the door and under the hood. what i am trying to do is wire the power wire for the tach, and the wire that controls power when you cut your lights on. i already have the actual tach read going to the MSD 6AL, and a location for the ground, i just need o figure out which is which for those other 2 wires.
    Main Power Wire
    Control Wire for cutting on the Lights
    Get'em tough get'em boosted. Start Boosting at a Young Age.
    basically i am trying to keep a clean look. i cant stand to see wires all over the place, and if i can keep from having to go through the firewall i will.
      B.u.m.p.
        ok..., just delete this posting
          ....Search for it? Power, Ground, Signal for the tach not that hard...or not that I know of.
            searched for it for the past few days, still no go . but i am going to plug the wiring into signal and a 12v power source.
