Carbon fiber vs. Heat.
    Will anything happen to a CF hood if it gets really hot? My turbo setup made a brownish spot on this metal hood that I have (its not painted) I just don't want to buy a CF hood and then have it heat warped or somethin.
    You have been defeated by a car with child locks, how embarassing...
    "I noticed my f22 felt "healthier" until it blew up." <Myk>
    I think CF is made to withstand heat really well, but I'm not sure.
    Is your turbo setup making your car hotter than it should be?
    Add some water wetter to you rad. and you temps should get better.
    (RIP)1993 LX Sedan
    Frost White Crew Member #36
    JDM Beating Stick Owner #1
    My (old) Ride
      i think it should be ok...but you should have got the vented VIS hood... i know if i go turbo that is what im gonna do ... sell my hood..and get something vented.
        nothing should happen to the actual carbon fiber but it will mess up the clear coat after a while and you will have to get it re-cleared.
          damn you turbo must be gettin red hot to turn you hood brown like dat hot boost = pointless try heat shielding your turbo and manifold and if you get a carbon fiber hood apply a square of dynamat above the turbo ya it'd look dumb but so would a fucked up CF hood
          p.s. dynamat xtreme not regualr dynamat....xtreme resists heat
          -sean
          Members ride 15.927 @ 86.76 (f22a1)
          Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
          Arcadia Green Crew #10
            you might be able to put some heat wrap or insulation on the bottom of your hood to prevent it from getting too hot. do that with a vented hood and you should be fine. just look at a first gen eclipse or talon. they have some sort of insulation to prevent them from getting hot.
              or you could be stupid and go hoodless,lol
              (RIP)1993 LX Sedan
              My (old) Ride
                Build a heat-shield for your turbo. Install a manual fan switch maybe.....
                1992 Accord LX - SOLD
                  i'll go for the vented CF hood and heat wrap the manifold... do you guys know if those vented CF hoods on ebay look good on our cars? i was interested in this one http://cgi.ebay.com/ebaymotors/Honda...spagenameZWD1V will those air vent pockets make the hood kinda high or are they flat on there?
                    What he said. Its really not that hard to make a heat shield yourself.
                      what do i make it out of?
                        Plastic.....No you dont... use metal. Same stuff they use on exhaust systems. Its like SUS 303 or something like that forgot or just some thicker metal. You just need to bend it a lil hear and there and bolt it down.
                          just plain old metal? hmm ok
                            thats why greddy kits come with heatshields . Is it a custom kit or dsm kit. ?
                              the carbon fiber itself will be fine but the clear coat is 50/50. if you get a cheap hood (ebay shit) the clear coat will fade. if you get a quality hood (vis, c-wings etc) you'll be fine. those cheap hoods are cleared with some shit like a gel-coat. put a couple or washers between the hood and hood hinge to angle the hood up in the rear for increased cooling and so what somebody else said about water wetter.
                              heres a pic of a cheap ebay hood
                              after i cleared it
